Re: farmall 140 oil pressures
Posted by Hugh MacKay on April 06, 2008 at 12:12:48 from (209.226.106.120):
In Reply to: farmall 140 oil pressures posted by kmm on April 06, 2008 at 08:10:54:
kmm: I've got a 130, it's been doing that for 25 years and up until 4 years ago I used it enough to burn 500 IMP gallons of gas yearly. I still probably burn a 100 gallons. As gene quite normal.
You can make it better by work on oil pump, but as long as it's pumping oil I wouldn't bother. Even a few pounds pressure indicates it is pumping oil.
