Re: Farmall 706 LP tractor
Posted by Kelly C on April 06, 2008 at 09:37:40 from (75.168.32.128):
In Reply to: Re: Farmall 706 LP tractor posted by martin simmons on April 06, 2008 at 07:37:21:
Yes if you get it started and plan on using the tractor. Replace all fluids and filters.
Now dont just change the fluid in the rear end unless your sure you are going to keep and use the tractor.
The capacity for the hydralics is 17 gal. That will run you about $160 or so plus the filter.
Order the manual. There is a place that sells all the IH manuals. I will email you the address. When I try to post it. The stystem stops it. I guess they are a competitor.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
