Magman is on target. Unless the ignition switch is bad, the problem is in the voltage drop. Put a volt meter on the coil terminal. if around 5 or 4 volts it won't start. Put in a ford type srarter relay to replace the one in it . wire the I terminal to the coil Negative terminal (bypassing the ballast resistor. This gives 10 volts to start it. Works well. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
