wiring on 400 international
Posted by roger forch on April 06, 2008 at 15:30:27 from (67.55.179.86):
the tractor was converted to 12 volt and it is set up so that the engine will not start while the starter is engaged. you have to let go of the key and then it will start if it has enough momentem. i think it is wired wrong somewhere. does anyone have a revised wiring diagram for conversion to 12 volt or any comments?
