Magman is on target. Unless the ignition switch is bad, the problem is in the voltage drop. Put a volt meter on the coil terminal. if around 5 or 4 volts it won't start. Put in a ford type srarter relay to replace the one in it . wire the I terminal to the coil Negative terminal (bypassing the ballast resistor. This gives 10 volts to start it. Works well. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
