Martin, all you are really doing is using the small tank instead of the tractors tank. the little diagram shows the fuel spply line(red) disconnected from the valve on the tractors tank(green) and then you have to match up fittings to connect the small tank(yellow) to the fuel line(red) that run straight down from the valve. I am assuming that the shut offs are as you look forward from the seat, thats the way it is on my 300LP. The double lines can prabably be replacated with some good hydrualic type lines and some good clamps, I believe those are low pressure return lines so you dont need the hyd. ends. Hope this helps and let us know
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
