Posted by Charles Todd on April 06, 2008 at 19:48:18 from (205.242.95.137):
I had asked this earlier and several people said there was a "standpipe" in the lift sump. I pulled the cover off (under the seat) and this is what I found.
I did not find a "standpipe" anywhere and I probed around and did not find a plugged drain hole. Didn't someone also say that they pulled a pipe plug to let this oil drain back into the main reservoir?
I am leaking like a crazy here,
Please advise. I have not started the tractor (Farmall 504D) in over 2 weeks, I would have assumed the oil should have returned by now.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
