Super A starts with the starter WOW
Posted by Rob Baird on April 06, 2008 at 20:08:39 from (68.59.165.228):
HI Everyone
Hugh i talked to you when I brought this tractor home about ring gear being bad in one place. I wanted to split it and fix everything. I have not had 400.00 for all the parts. I took a 3 corner file and filed the teeth inthe bad spot then the rest of the way around the flywheel. I bought one of the new clutch type starter drives. So far so good. I guess the bad spot was not quite as bad as it looked. I probably spent over 4 hours filing though. I was getting tired of cranking so decided to give it a shot. Having to mow grass for the second time here in Florida
