Re: HELP!! 504 Hydraulic System Noise
Posted by Raymond Amos on April 06, 2008 at 21:12:14 from (12.226.178.119):
In Reply to: Re: HELP!! 504 Hydraulic System Noise posted by Allan In NE on March 22, 2008 at 09:00:05:
You may be getting cavitation because your pumps inlet pressure is dropping to low. Very bad for pump life if not stopped. If your filter is not clogged, you may have to find some way to decrease the restricked flow to the pump.
