Re: Any ideas or tips on a corn planter?
Posted by magman on April 07, 2008 at 02:54:43 from (66.82.9.57):
In Reply to: Any ideas or tips on a corn planter? posted by jonnny2006 on April 06, 2008 at 19:43:12:
What part of the country are you in?
This is what I do for my corn .
I work the ground Up with my discs, then I broad cast the corn go over it with the discs and it usally takes pretty good. If I want rows I cultivate with the cub. I wish I could find a corn planter for my cub here in NY cheap my self.
You could also see if there is a farmer in the area that can run his no till over it with your seed also a sprayer with some round up first would be great.
JON
