Re: 706 charging problems revisited
Posted by Weldon K on April 07, 2008 at 08:08:39 from (98.16.27.205):
In Reply to: 706 charging problems revisited posted by TJH72 on April 06, 2008 at 12:59:18:
If the batteries are good , the alternator is good, the voltage regulator is good, all wiring is good and connected properly, only thing left is the resistance unit.It is found either just above or just below the voltage regulator. It is the porcelain thing with wire terminals at each end , fastened in place with one small bolt. I've replaced several of them over the years for myself and others when batteries would not charge.
