Re: Hydraulic Woes...
Posted by Charles Todd on April 08, 2008 at 07:07:23 from (205.242.95.135):
In Reply to: Re: Hydraulic Woes... posted by the tractor vet on April 07, 2008 at 22:21:20:
I agree, safety is first with compressed fluids. I have seen first hand the damage oil under skin can cause, permanent damage.
The steering works ok until you load the tractor up then it gets to a hit or miss, hard then easy. After rebuilding the remote valves, I can raise the loader at low idle. But it lacks balls with a load. I spoke to my father and he did say that years ago he suspected the hydraulic pump was failing and that is why he "retired" it to the round baler. Now I have it and trying to fix all this worn out do-do is taking longer and longer because I am finding more and more.
Whatca think, if the pump is original and the filters are good, and I put a gauge on it and get less than 1650 psi, bad pump??? Also I have heard that you can get a 1850 psi or 2050 psi relief from an industrial that will replace the 1650 psi relief. Anyone have a part number???
Thanks guys, I can be a PITA,
Charles
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
