Re: 1939 H Hydraulic Oil?
Posted by CNKS on April 08, 2008 at 17:10:18 from (216.144.104.128):
In Reply to: 1939 H Hydraulic Oil? posted by Tom B. on April 08, 2008 at 16:53:09:
The pump really doesn't care what is in it. If you are satisfied, don't change. You may see more leaks, and it may not give the pressure of 30W, but again if it works leave it alone. I don't have a loader, but I believe the reason for not using the fill opening for a return is the possibility of it squirting out the vent. Same recommendation as above.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
