Re: 1939 H Hydraulic Oil?
Posted by Charlie M on April 08, 2008 at 17:54:19 from (70.101.104.228):
In Reply to: 1939 H Hydraulic Oil? posted by Tom B. on April 08, 2008 at 16:53:09:
The only problem with the lighter weight oil will be if it gets hot from a lot of use then it will cause a loss of hydraulic pressure as the oil thins too much. If you system is working for what you are doing then there isn't a problem, I'd leave it the way it is.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
