Re: crankshaft theory question
Posted by Janicholson on April 08, 2008 at 19:37:04 from (64.83.197.92):
In Reply to: crankshaft theory question posted by P and R Pete on April 08, 2008 at 13:38:14:
Many of the 4cylinder IH engines are ballanced only because the parts are moving in opposite directions at the same time. Two pistons up, (on the ends) and twodown (#2-3) This is intrensically ballanced, as long as the pistons, and rods are all the same WT. The aluminum pistons weigh substantially less than the cast iron (earlier) pistons. Even so, no crankshaft ballancing is required. So there is no crankshaft ballance related to the Flywheel, or Pulley. They are ballanced individually, with no regard to their effect on the crank. JimN
