Re: My Findings on Actual Hydraulic Output PSI, Maybe Low?
Posted by the tractor vet on April 08, 2008 at 19:54:34 from (76.212.231.52):
In Reply to: Re: My Findings on Actual Hydraulic Output PSI, Maybe Low? posted by Steven f/AZ on April 08, 2008 at 18:06:51:
Myself and a good friend that was a machinery jockey we both ran 706 gassers fro loading equipment and unloading i set both tractors up mine had a 2000 seires loader and my buddy's had a Do All both had the 2100 pressure relief in them and i could just lift a 15 foot brillion culamulcher my buddys could do it a little better as his had larger cylinders on the lift Now we never broke the tubes but did break the spindles several times. and sheared the pins while tryen to move with one hanging off the end of the 6 foot boom pole. . They has enough lifting power to lift the whole back end of a farmall M with a 319 picker mounted to it after it snapped the axle off in the field . Was to soft to use a jack while we changed out the axle . That job did not fall under OHSO standards.
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
