Farmall A Spec's
Posted by JOE SEARLES on April 09, 2008 at 08:40:06 from (74.75.30.241):
I have a Farmall A with a 113 eng. I need to know the timing procedure and also spec's for valve clearances and magneto settings and torque values for the head and bearing caps and etc. I am rebuilding the tractor and the manual I have does not give me this info as it is parts only
Any help would be greatly appreciated.
Thanks,
Joe
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
