Re: Farmall M trans shaft seals
Posted by Haas on April 09, 2008 at 17:39:37 from (12.65.18.106):
In Reply to: Farmall M trans shaft seals posted by onefarmer on April 09, 2008 at 17:25:33:
Some folks will tell you to use two of the new seals. That is not necessary and one of the new seals will be better than the old seal ever was provided the surface that it runs on is in good condition.
