Re: Tie Rod Ends
Posted by Daniel H. on April 09, 2008 at 19:30:28 from (66.226.34.159):
In Reply to: Re: Tie Rod Ends posted by tn terry t on April 09, 2008 at 16:45:13:
Try A&I products. You use the IH part number, but their prices are much cheaper. I try to buy from Case/IH when I can but, the long notched ones (360412R11)are around $45.00 from them and $210.00 from Case/IH. The short ones (356540R91) are $16.00 from A&I and $33.00 from Case/IH. The tubes are also available. The only problem I ran into with the A&I tubes is the narrowest setting (44") will not work with out trimming 3/8" off the long tie rod. I think it is due to the way they form the taper on the tubes. Most people don"t use the 44" tread, so it isn"t a big issue. Be aware there are two different tubes 7/8" and 1"OD, and the part numbers for the 7/8" OD are different.
