Re: IH 400 motor
Posted by D Slater on April 09, 2008 at 20:01:40 from (71.164.37.45):
In Reply to: IH 400 motor posted by Paul in WI on April 09, 2008 at 13:46:39:
If you have a 54 model, original didn"t have a dipstick until into 1955. Most gasoline and LP engines didn"t have openings in pan for petcocks.
Unless you have a diesel block casting numbers are located above oil filter on engine block. Casting # for original block is 356980 R1 or R2. R1 didn"t come with dip stick and R2 did. C281 engines in 450 tractors also used 356980 R2 blocks.
Farmall tractor serial 10870 was the first one with dip stick and W 400 # 819.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
