Posted by John Franklin on April 10, 2008 at 01:48:35 from (76.106.36.255):
I have a Super A, 6v positive ground, that for now has a dead battery. I think the battery is probably 5 yrs old.
Before removing the generator & regulator to take it to some place to have tested, is there a way to test the system to see which part isn't working. If I put a another working 6v battery on it, is there a procedure I can follow to test the battery.
BTW, when I pull started the tractor, the ammeter shows no charge. In fact, it shows no negative charge either.
A couple years ago I had the VR and generator tested and the generator needs a bushing and it was repaired. Those worked ok then.
I polarized the generator when I installed the new battery years using a jumper wire momentarily shorting the BAT and GEN terminals on the VR. Was that procedure correct?
