Kwick fix would be to ground the field terminal on the generator and then see if it charges. Check all parts for ground gen,regbase,control in the dash. I use an ohm meter to check for ground and yes you didpolarize it correct and mite need to do it again.I see lots of newer paint and you mite need to clean all connections and possible you batt is over the hill. I usually get 5-6yrs out of the 6v ones sometimes more. Check all connections on the batt also and then check the level of the electrolite in the batt. Plenty of things to check just a matter getting them done.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
