Farmall M and C hydraulic questions
Posted by Learning2Pull on April 10, 2008 at 15:07:02 from (74.236.250.244):
For starters, my M has four hydraulic outlets, two right next to each other on the left, and two several inches apart on the right as you're sitting on the tractor. Can I use a two-way cylinder with these or not? Which are supplies, and which are returns?
Secondly, I am looking at pulling a V rake (8 wheel) with a Farmall C... IS there any way to add hyd. remotes to this thing? It does NOT have an adjustable drawbar, only fixed, but it does have the belly lift.. what is the easiest way of putting hyd. on it for a single cylinder V rake?
