Posted by JayIHMan on April 10, 2008 at 16:51:27 from (65.64.191.81):
In Reply to: Re: 7130 issues posted by chucky on April 08, 2008 at 17:48:10:
On the left hand side behind fuel aux tank (if equiped)you will find the hitch valve. Locate the small line that goes to large pump on right side of unit, cap off line that goes to the hitch valve. This will require a face fitting(Flat) plug to do this. Start unit and see if remote flow is regained. You also mite have had an orfice come loose in priority valve located behind remotes next to transmission. I would suggest a visit to your local Case dealer for the plug to block the signal line. Hope this helps.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
