Re: oil pressure transmission line
Posted by CNKS on April 10, 2008 at 17:44:50 from (216.144.104.128):
In Reply to: oil pressure transmission line posted by Mike CA on April 10, 2008 at 17:30:45:
It's supposed to be tight, it was probably a little loose in order to align the line with the fitting. The fitting on the gauge is supposed to be tight also. The line will be loose as you loosen the fitting, the fitting will slide on the line. I don't remember if that line is flared or if it has a compression fitting.
