Re: Stuck engine #3
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by ltf in nc on March 07, 2000 at 15:56:23 from (206.228.213.65):
In Reply to: Stuck engine #3 posted by Frog Level on March 07, 2000 at 15:28:02:
You had a valve stuck. This could have been veried and possibly corrected had you pulled the valve cover as suggested. Yes, you are now going to have to pull the head. Try to double nut the studs and see if you can get some of them out. Attempt to remove them with an impact wrench if you have one.
Post A Followup
: Re: Re: Stuck engine #3
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
