The hex pipe coupling by your little finger should be threaded on the oil gauge. You may want to use teflon tape or pipe dope on the male pipe threads on the gauge and then tighten.
Slide the hex tube nut near your thumb onto the tubing. Then install the furrule with taper toward the tube fitting in the coupling. Then tighten. Hal PS: You probably should put teflon tape or pipe dope on the pipe threads of the tube fitting that's screwed into the coupling.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
