Re: 560 motor swap NEED HELP!!
Posted by ejr-IA on April 11, 2008 at 20:30:20 from (204.11.182.12):
In Reply to: 560 motor swap NEED HELP!! posted by UncleBubbIH on April 11, 2008 at 18:13:20:
use the 560 flywheel I have did several.The diesel I used came out of a 403 combine.Theirs one problem you can over come is the oilfilter base which you have to use from the 560 which is the cast iron one.Consists of boreing and pluging a hole in the block.When you get to that point and have a problem post and I will try to help you.
