ejr-IA said: (quoted from post at 20:30:20 04/11/08) use the 560 flywheel I have did several.The diesel I used came out of a 403 combine.Theirs one problem you can over come is the oilfilter base which you have to use from the 560 which is the cast iron one.Consists of boreing and pluging a hole in the block.When you get to that point and have a problem post and I will try to help you.
There was a replacement oil filter base released for use on 560 tractors when using a new replacement block. If you can find one of those it will work on the newer blocks with the relocated oil galleys and still allow clearance for the steering shaft. It is cast iron and uses a spin on filter.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
