bull pinion bearing replacement for H
Posted by Matt from wi on April 12, 2008 at 16:00:48 from (98.144.10.146):
While replacing bull pinion shaft oil seals for a brake job. I noticed a bad bearing on the right side bull pinion brake shaft. What do i need to remove to get at this bearing? What else should I look for while Iam in there? It looks like I need to remove the transmission cover and belt pulley assembly any experience and help would be apppreciated. Thanks Matt
