Re: bull pinion bearing replacement for H
Posted by riverbend on April 12, 2008 at 22:21:39 from (208.160.34.209):
In Reply to: bull pinion bearing replacement for H posted by Matt from wi on April 12, 2008 at 16:00:48:
Get an I&T manual for your tractor. Plan on removing the top cover. Buy the correct heavy duty bearing for the bull pinion (about $100). Check that the pinion bearing in the transmission input shaft is good.
It is a lot of work, but nothing too tricky. The second time you do it, you can have it back together the same day.
Greg
