Re: M carb leak
Posted by Red Mist on April 12, 2008 at 17:32:09 from (208.61.168.150):
In Reply to: M carb leak posted by Zach Bouchard on April 12, 2008 at 17:13:39:
My old eyes might be failing me, but I have never seen anything quite like that before. Usually there is just a needle protruding with an exposed packing nut.
Typically, you would need a new packing. They are available from your case/ih dealer. Be careful with them as they will break easily until installed in the carb. I usually carefully slide them onto the needle first, then screw the needle into the carb and carefully tighten the packing nut.
In a pinch, I have also used 4 or 5 o-rings. I used a size that would just slide onto the needle. The packing nut then gave them enough pressure to seal everything. mike
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
