Dan, Several things can cause this, to get it primed locate a plug on the left side below the oil pressure sending unit, it faces the rear of tractor and takes a 5/8 wrench. Remove that plug then apply air pressure to the filler dipstick tube "no more or no longer than needed" at the same time crank starter until oil squirts out. Replace plug and start engine. If pump and unit is okay this should get it working, if the problem repeats itself you may have a bad pump or an air leak caused by a poor o-ring, then find a good mechanic to help you. Good luck, Chuck
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
