856 - Changed trans filter and now have no steering....
Posted by Dan Swanson on April 12, 2008 at 19:17:44 from (63.172.252.161):
I bought the tractor a couple of weeks ago. Steering, clutch, and hydraulics worked fine. Thought I would change all the filters. Changed the trans filter took out a Wix filter and put in a Fleet Guard from the dealer. The transmission oil level was at the low mark before the filter change. I changed the filter, then filled it to the full mark. Started the tractor, the transmission light blinks, along with the Alt. lite. they won't quit. The alt. lite might be a wire problem because it has others too. I pressed in on the clutch several times, I can shift into the gears but if you let out on the clutch it doesn't move. I did however get the tractor to move once then shifted gears and then nothing again. I read the manual on how to purge the air out if there might be some. The tractor has a loader on it so I lifted the front wheels off the ground and turned the steering back and forth several times but it was still very hard to do. I moved the hyd. levers back and forth several times too. I am going to hook a hyd. cylinder up to the hydraulics tommorrow and see if I can get that to work. The PTO, which has it's own pump works fine. Any ideas?
Thanks, Dan
