Re: 856 - Changed trans filter and now have no steering....
Posted by the tractor vet on April 12, 2008 at 21:27:51 from (99.167.214.160):
In Reply to: 856 - Changed trans filter and now have no steering.... posted by Dan Swanson on April 12, 2008 at 19:17:44:
A simple way to BLEED the system is to run the engine at 1800-2100 RPM and TURN THE STEERING WHEEL TO THE LEFT and this will BLEED the trapped air . NOW if his does not work then it is time for a new MCV pump . Now as to the tell tale lite for the alt , it may be a bad connection and it may be that the alt . thought that this was a good time to die.
