hydraulic problem on 350 valve stack.
Posted by Greasy John on April 13, 2008 at 12:41:42 from (216.228.193.141):
Need Help again!Got the 3rd control valve mtd and hooked up to single action cyl.on the loader hoist.I assume the oil is supposed to go back to the resorvoir when lever is pushed to down position (back thru the same line)??valve set to single.Not my luck-seems to put a load on the engine unless the valve is pushed forward very quickly. NORMAL ??What am I doing wrong ?tried it on the other valve with same results. This valve works fine on the double acting dump cyl.Thanks .
