Re: hydraulic problem on 350 valve stack.
Posted by Roger46 on April 13, 2008 at 18:24:19 from (69.58.159.42):
In Reply to: hydraulic problem on 350 valve stack. posted by Greasy John on April 13, 2008 at 12:41:42:
I am currently overhauling my 350 valve stack. In my manual it shows that apparently there is always pressure on the system so that when you open a valve it will react instantly. When no cylinder is being operated, the oil is recirculated back to the reservoir through a regulator valve. The only difference between single acting and double acting cylinders is in single acting the oil is either pumped into the cylinder or drained and the double acting cylinder the oil is pumped from one end or the other. Rotating the valve from single to double changes the way the ports line up in the valve to allow this to happen. Roger
