Re: cylinder head studs
Posted by CNKS on April 13, 2008 at 13:22:38 from (216.144.104.128):
In Reply to: cylinder head studs posted by P and R Pete on April 13, 2008 at 12:50:44:
Clean the threads on the studs and run a tap into the holes in the head, making sure you get all the filings out. In my opinion the loctite is not needed. Taps are inexpensive, you should be able to do that yourself, if that's what you mean. Some people recommend replacing the studs in your situation.$$$.
