340 utility adjustable front axle problem
Posted by tesmith66 on April 14, 2008 at 05:47:57 from (130.76.96.19):
The bolts that go through the center of the tube to index the front end spacing are stuck good. I got the clamp bolts out and the lower part of the clamp came off with a good whack, but these bolts are really stuck. Any ideas? I whacked one from the bottom enough to upset the end (had to cut that part off), and I heated both ends up red hot and let them cool, hoping that would loosen their death grip, but that didn't work, either. Is the inner axle tube solid or hollow? If it's solid, I guess they aren't coming out, are they? I might torch the ends off enough to get the axle to slide out, then just use new bolts and leave the old ones in there. any suggestions?
