Posted by bigr on April 14, 2008 at 13:35:46 from (209.225.102.58):
In Reply to: Re: 10-20 start-up posted by Bob Kerr on April 13, 2008 at 19:27:15:
It has the E4A mag on it. That was the replacement, I don't remember what the original was that I haven't seen for a while. It has new plugs, new wires, fresh oil change, radiator clean and full. I put a single pole mag switch on it because I couldn't figure out how to shut it off. My mag lever works front to rear not side to side. If you look at the aluminum cap from the seat, the cap to the left would be off and the cap turned towards the right a 1/4" would be starting position, correct? At that time you would turn the mag switch on, correct? As far as timing I would get the front cylinder to TDC and then the cap on the mag should be at no. 1? I'll try sending you photos. Thanks!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
