Jim N need help
Posted by Matt from wi on April 14, 2008 at 17:30:35 from (98.144.10.146):
Jim, while attempting to slide the axels out on my H to move the bull gear out of the way access the bull pinion shaft. I used your advise of putting a spacer between the two bolts on the bull gears. The rear axle moved out 3/4 inch and is bound up. I do not want to use excessive force. The tire is off the ground. Is there something on the rear axle I need to disconnect I cant see anything in the parts book? Thanks Matt
