Re: Jim N need help
Posted by Janicholson on April 15, 2008 at 06:04:55 from (199.17.6.122):
In Reply to: Jim N need help posted by Matt from wi on April 14, 2008 at 17:30:35:
There should be nothing causing that to happen as far as I know. The Wt of the tire might be a factor. Look in the archives here to see if there is further info on the topic. --Bull gear removal--
One way to get pressure off of the axle would be to Place a plywood square under the tire, and on top of 3 or 4 small diameter rollers (maybe 1/2" pipe) then let the axle down enough to rest on that support. It may be necessary to remove the axle seal retainer where the axle is visible on the housing, but it has been a long time sense I was doing it. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
