Re: cylinder head studs
Posted by Edpap on April 14, 2008 at 21:33:37 from (74.33.236.203):
In Reply to: cylinder head studs posted by P and R Pete on April 13, 2008 at 12:50:44:
i would look over the nuts real good they could be pulling the threads. also mesure the studs to see if any are longer they might have streched. did you put oil under the nuts? if not it could have been binding. if you were at 70lbs on the last nut and you removed the head i would replace the gasket. I never use loctite on studs the next guy to take it out won't like you too mutch
Good luck Ed
