Re: Where to get 00 battery cable for 350 utility?
Posted by PaulW_NJ on April 16, 2008 at 04:15:28 from (71.187.55.168):
In Reply to: Where to get 00 battery cable for 350 utility? posted by mickey350 on April 15, 2008 at 21:44:56:
I've bought mine at McMaster Carr (McMaster.com), as well as solder filled lugs and terminals.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
