Re: M Diesel ~ they good runners ?
Posted by old on April 16, 2008 at 21:49:30 from (4.244.219.107):
In Reply to: M Diesel ~ they good runners ? posted by chisel_plow on April 16, 2008 at 20:59:10:
Thats a yes, no and sort of. If all if well yes but if it has carb problem no. They start on gas and then when warm switch to diesel. Lots of power if all is well but cost big bucks if you need to work on them
