Re: 140 running away
Posted by tn terry t on April 17, 2008 at 05:53:55 from (64.12.116.144):
In Reply to: 140 running away posted by Farmallgray on April 16, 2008 at 18:01:42:
I would like to add just a little to Brownie 450's post if ya dont mind
while your checking that throttle rod take it loose at the clevis and hold the carb closed and set the gov arm to idle with the steering mounted throttle to check that the clevis is adjusted right if its not real close it will cause your problems. I think it was Rustyfarmall who taught me this trick to cure my A it was doing the very same thing you are talking about
