Does the TA work -- If you can separate the TA slippage from the clutch, put it in 2nd or third with the TA in low range let out the clutch and stand on the brakes. If the tractor slows as it should the "TA" is likely ok. Clutch replacement at a shop is likely several hundred dollars, TA replacement much more. Replacement TA alone (parts only) is about $600?? Remember that when either is installed, the Clutch and TA each must be adjusted. I'm not an expert on either.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
