Re: advise on clutch replacement?
Posted by Kevin Meier on April 17, 2008 at 18:38:13 from (64.71.85.247):
In Reply to: Re: advise on clutch replacement? posted by CNKS on April 17, 2008 at 10:57:14:
I have the ta they are $625 core included plus you would need the gasket kit that"s $105 and probably the ta clutch and flywheel may need replaced that"s another $180. Just follow the intructions that you have been given and make sure your t/a is good one way or another. Personally if the t/a needs replaced I would do the clutch and all while it"s apart though.
good luck
Kevin
