You can buy a kit. Probably around $400 these days. Go to Worksaver.com. Maximum lift capacity is 500 lbs or less depending on how good your touch control unit is. When you install the 3 point, the drawbar goes away, so you have to use a cross bar in the 3 point hitch for drawbar work. The lift range is also somewhat limited, so it does not work for all implements. I don't think I would try to plow with one. I used to use mine for a carry all, grader blade, and a small pickup disk. It also worked great with a post hole digger, but I had to adjust the hole digger so that it would pick up high enough to work. The down pressure was a big plus with the hole digger.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
