Re: Broken Super H clutch housing
Posted by tubby on April 17, 2008 at 19:11:39 from (96.230.22.39):
In Reply to: Broken Super H clutch housing posted by Andrew Kappers on April 17, 2008 at 17:01:00:
I have a 1953 super h that is totally disassembled that I will part out and sell you the housing. If you tell me how to check the date code I will see if it is correct. I am sure it is a 53. If you are interested my email address is jadamstubby@yahoo.com....Thanks
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
